Date/Time: Fri, 30 Oct 2026 15:11:30 +0000
tool background
View Count: 1196
[2014-12-02 19:19:48]
GCAdmin - Posts: 35
When you set on a tool to have opaque label background, the label doesn't stay opaque if you copied the drawing from another chart. Is there a way to fix this?
[2014-12-02 21:25:18]
We think the problem is actually something else having to do with the draw order. Refer to this section here:
http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DisplayOrder
Date Time Of Last Edit: 2014-12-02 21:25:50
