Date/Time: Fri, 30 Oct 2026 15:11:28 +0000
Serious Data Issue (5min ES CME[M] Feed)
View Count: 1358
| [2014-12-02 15:30:59] |
| User15952 - Posts: 137 |
Yesterday at 13:45 the high is showing 2058.25. I have compared this with two other data sources. CQG and Trade Navigator and it is out by a tick. On both the other platforms the high is 2058.50. Was there are problem with the data yesterday from CME? |
| [2014-12-02 21:52:57] |
The data on the servers is correct: http://www.sierrachart.com/image.php?l=1417557133176.png We recommend re-downloading the data from before that bar. Here are the instructions: http://www.sierrachart.com/index.php?page=doc/helpdetails2.html#h2.1.2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
