Date/Time: Fri, 30 Oct 2026 15:11:53 +0000
Micro Euro/Dollar futures
View Count: 1910
| [2014-12-02 14:55:04] |
| User838407 - Posts: 3 |
what is the full SC symbol for the M6E
| [2014-12-03 03:40:05] |
We see you are using Interactive Brokers. In File >> Find Symbol you will see this listed as: M6E-######-GLOBEX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
