Date/Time: Fri, 30 Oct 2026 15:10:54 +0000
closing auction
View Count: 1442
| [2014-11-25 11:32:17] |
| nicktrader - Posts: 817 |
In the attached file you can see a M60 and a M5 Chart (smaller one). In both charts you can see one (or even two last day) bars at the end of the day (see red arrows). OHLC has the same price. I assume it is the closing auction. Is it possible that the closing auction is part of the last really traded candle of the day. The big problem of the closing auction bar is the negative influence of the EMAs. |
| [2014-11-25 18:08:49] |
You can adjust the Session Times to filter these bars out. Refer to this page: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
