Date/Time: Sun, 27 Sep 2026 17:06:15 +0000
New Spreadsheets OR function
View Count: 1325
| [2014-11-20 23:17:11] |
| Sawtooth - Posts: 4355 |
This works: =IF(OR(A4=0,INT(A3)>INT(A4)),K4+1,K4) This gives a #VALUE! error: =IF(OR(INT(A3)>INT(A4),A4=0),K4+1,K4) Both formulas work in the Old Spreadsheets version. It errors because row 1003 is blank with a 1000 Number of Rows setting. In the Old Spreadsheets version, I don't need to check for a 0 in row 1003: =IF(INT(A3)>INT(A4),K4+1,K4) 1) Why is there a precedence in the OR function? 2) Why is there now a need to check for a 0 in a blank row beyond the Number of Rows setting? |
| [2014-11-24 17:59:55] |
1. 1) Why is there a precedence in the OR function? 2. 2) Why is there now a need to check for a 0 in a blank row beyond the Number of Rows setting? It is not necessary to check for 0 in a blank row, however the INT function returns a #VALUE! error if it is given an empty value, as is described in the description for the function: Rounds the given Number down to the next whole integer. Returns #VALUE! if the given Number is not a number.
Therefore, checking that A4 is not empty before the call to INT is necessary to not get a #VALUE! error on the last row. 3. The Old Spreadsheet's INT function returns 0 when it is given an empty value. 4. We have changed the INT function of the Internal Spreadsheet Components to return 0 if it is given an empty value. This will be out in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
