Date/Time: Fri, 30 Oct 2026 14:18:18 +0000
QuoteBoard is empty
View Count: 1373
| [2014-11-20 02:13:49] |
| brown555 - Posts: 35 |
I'm connected to Interactive Brokers. All variables are 0.0/0.00/etc.
| [2014-11-20 03:09:34] |
In general, this is hard for us to help with because we do not provide the data. It comes from Interactive Brokers. Make sure the symbols are correct and try reconnecting to the data feed with the commands on the File menu. We also recommend contacting Interactive Brokers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
