Date/Time: Fri, 30 Oct 2026 14:19:05 +0000
[Locked] - Rithmic connection down, second time this week.
View Count: 3495
| [2014-11-19 16:20:37] |
| tfh6252 - Posts: 20 |
Do we have any feel as to whether this chronic problem will ever be solved? Is it a hardware deficiency, or an ongoing coding issue? I lose connection at least three times weekly, typically in this fashion. I reported this over the weekend, last Saturday also. Tom Rithmic Trading | Connecting to the server 127.0.0.1. Port 50135 | 2014-11-19 10:15:22 Socket (1036) | Connected. | 2014-11-19 10:15:22 Rithmic Trading | Connected to server. | 2014-11-19 10:15:22 Rithmic Trading | Sending logon request message. | 2014-11-19 10:15:22 Rithmic Trading | Starting the connection process to data and trading service. | 2014-11-19 10:15:22 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-11-19 10:15:22 Rithmic Trading | Connecting to Rithmic 01 US server. | 2014-11-19 10:15:22 Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-11-19 10:15:23 Rithmic Trading | Server Alert: Trading System Connection Opened | 2014-11-19 10:16:00 Rithmic Trading | Server Alert: PnL Connection Opened | 2014-11-19 10:16:41 Rithmic Trading | Server Alert: Intraday History Connection Opened | 2014-11-19 10:16:41 Rithmic Trading | Server Alert: Trading System Connection - Heartbeat has been quiet for 43.469 seconds. | 2014-11-19 10:16:43 Rithmic Trading | Server Name: DTC Bridge. | 2014-11-19 10:16:43 Rithmic Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-11-19 10:16:43 Rithmic Trading | Logon error from server | 2014-11-19 10:16:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-19 10:16:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-19 10:16:43 Rithmic Trading | Deleting API object. | 2014-11-19 10:16:43 Rithmic Trading | Server Alert: Intraday History Connection Closed | 2014-11-19 10:16:43 Rithmic Trading | Server Alert: PnL Connection Closed | 2014-11-19 10:16:43 Rithmic Trading | Server Alert: Trading System Connection Closed | 2014-11-19 10:16:43 Rithmic Trading | Server Alert: Market Data Connection Closed | 2014-11-19 10:16:43 Socket (1036) | Shutdown and closed. | 2014-11-19 10:16:43 Rithmic Trading | Disconnected from the server. | 2014-11-19 10:16:43 Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-19 10:16:43 Rithmic Trading | Port for executable: 50151 | 2014-11-19 10:16:45 Listening socket (1808), port 50151 | Closed. | 2014-11-19 10:16:45 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-11-19 10:16:45 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50151 | 2014-11-19 10:16:47 Socket (1808) | Connected. | 2014-11-19 10:16:47 Rithmic Trading | Connected to server. | 2014-11-19 10:16:47 Rithmic Trading | Sending logon request message. | 2014-11-19 10:16:47 Rithmic Trading | Starting the connection process to data and trading service. | 2014-11-19 10:16:47 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2014-11-19 10:16:47 Rithmic Trading | Connecting to Rithmic 01 US server. | 2014-11-19 10:16:47 Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-11-19 10:16:48 Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2014-11-19 10:16:48 Rithmic Trading | Server Alert: Trading System Connection Opened | 2014-11-19 10:16:48 Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2014-11-19 10:16:48 |
| [2014-11-19 16:35:02] |
| User35750 - Posts: 4 |
Yup I can confirm that my Rithmic is down too. I just spoke with Amp and they confirmed that Rithmic is down and they are working on it. I had this happen a few weeks ago but have not had the ongoing issues you are experiencing....
| [2014-11-19 16:39:27] |
| User120827 - Posts: 77 |
I cant connect rithmic on Sierra, but it is working fine with Multicharts . I am trading on MC right now as I had an open position when Sierra when it disconnected. shane |
| [2014-11-19 16:58:02] |
| User59724 - Posts: 71 |
Sierra Charts just connected again with Richmic after about 20 minutes off line.
| [2014-11-19 16:58:03] |
Wow that is interesting, my convo with amp led me to believe it was all of rithmic, thanks for posting....
| [2014-11-19 17:17:37] |
Even though MC stayed connected, I could not connect with RTrader either. I use RTrader by rithmic to connect in an emergency, but that did not work either. Support at Multicharts has informed me that I may have been receiving data , but they doubt I would have been able to actually place a trade. Weird, huh ? shane |
| [2014-11-19 17:30:18] |
| Zosimus - Posts: 345 |
can't connect to Rithmic here too.
| [2014-11-19 18:36:29] |
Connection is restored, but loading data takes 15 minutes(!) as it has all day...unacceptable. Running SC pkg five. Tom |
| [2014-11-19 18:55:48] |
If there is a problem with the downloading of historical data when using Rithmic, start a new thread on this support board about this. This thread is being closed.
