Date/Time: Mon, 02 Nov 2026 14:18:49 +0000
Vertical Line that shows wicks
View Count: 1292
| [2014-11-19 04:17:28] |
| User78926 - Posts: 69 |
Hi there, How can I draw a vertical line that does not hide the candle wick? I need this when measuring Delta, as I need to be able to view the wick length at the same time as using the vertical line. Your help would be appreciated. Rgds, Mark |
| [2014-11-19 04:26:54] |
Refer to this section here about drawing Chart Drawings underneath the price bars: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DisplayOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-19 04:27:28
