Date/Time: Mon, 02 Nov 2026 14:18:33 +0000
Adding Lines to built in study Demarker
View Count: 1740
[2014-11-17 09:15:30]
User95370 - Posts: 28
Hi, Can you add the option of adding lines to the built in study 'Demarker' just like you can add it in "Rsi" and "Stochastics" . Demarker also oscillates in a fixed range (between 1 and 0) like rsi and stochastics ( between 0 to 100) . Therefore it is important to have those levels marked in the chart itself.
[2014-11-17 14:19:05]
Sawtooth - Posts: 4359
Until that happens, you can use two instances of the Line study.
[2014-11-19 05:20:35]
Refer to the documentation for this here:
http://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#AddingHorizontalLine
