Date/Time: Fri, 30 Oct 2026 14:19:05 +0000
Zigzag Cumulative Volume displayed error LTP at zero value
View Count: 1582
[2014-11-17 03:57:51]
batman_ - Posts: 190
Please correct Zigzag Cumulative Volume that displayed LTP at zero value at column AA3 from spreadsheet trading system.
Refer to attached image, E3 showed a value for LTP and AA3 showed zero value for LTP. These E3 and AA3 from spreadsheet trading system have caused main price graph displaying a horizontal line instead of showing actual price movement.
Date Time Of Last Edit: 2014-11-17 05:01:13
imageZigzagCV.png / V - Attached On 2014-11-17 03:57:39 UTC - Size: 54.43 KB - 550 views
[2014-11-17 08:54:17]
Zigzag subgraph (SG1) should be removed instead of ignored by default to prevent main price graph showing two different LTP value. When i set trading signal logic from spreadsheet trading systems, the main price graph is showing a single horizontal LTP line due to two different value.
image2014-11-17_1649.png / V - Attached On 2014-11-17 08:51:08 UTC - Size: 32.97 KB - 524 views
[2014-11-20 04:32:53]
In regards to this:
1. Update to the latest revision of 1213 by selecting Help >> Download Prerelease.
There was a problem with the conversion of TRUE and 1 values from the Buy/Sell columns to the correct values for placement of arrows on the chart when using the Spreadsheet System studies.
2. The Zig Zag line will not always go to the end of the chart and the last bar unless there is a new swing at the last bar in the chart. Therefore, the Spreadsheet column which outputs this data may have zeros for the most recent bars in the chart.
Date Time Of Last Edit: 2014-11-20 04:44:24
