Date/Time: Sat, 21 Nov 2026 16:16:41 +0000
Trouble using Study Subgraph Add for extending High/Low For Time Period
View Count: 2098
| [2014-11-15 19:20:10] |
| OneMoreTick - Posts: 79 |
On ES, I'm using the "High/Low For Time Period - Extended" study to show me the high and low for a specific time period. I'd like to put horizontal lines on the chart 2pts above the high and 2 pts below the low. When I use "Study Subgraph Add" it's adding the lines (I'm using dash as the draw style) at the high and low but also at 0 which is distorting the chart. How do I get it to not show the dashes at 0? http://www.sierrachart.com/image.php?l=141607900987.png |
| [2014-11-15 20:56:36] |
To the next version of Sierra Chart, the study will have this new input: Add To Zero Values In Based On Study You will need to set it to No to solve this problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
