Date/Time: Fri, 30 Oct 2026 14:18:17 +0000
Replay Chart
View Count: 1224
| [2014-11-14 00:03:59] |
| rwilliams1 - Posts: 347 |
When using the Replay Chart feature, I noticed the replay is no longer working. It automatically skips to the very end of the chart when the replay feature is started and does not run. it was working fine a couple of weeks ago, but no longer is now.
Date Time Of Last Edit: 2014-11-14 01:58:18
| [2014-11-21 03:44:29] |
Just following up on my previous post. The Replay chart features seems to work sometimes, but at other times I'm still experiencing the problems described above. It's frustrating because I cannot seem to find a solution. I'm curious if tech support has seen this issue before, and if so, if you could suggest any solutions? Thanks.
| [2014-11-21 03:51:39] |
We definitely do not think there is any problem with the replay functionality. There must be some other explanation for the problem. Review the documentation here: Replaying Charts Also make sure there are not out of order timestamps in the chart by selecting Edit >> Delete All Data and Download Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
