Date/Time: Mon, 26 Oct 2026 19:38:54 +0000
Voloume at price - Threshold alert
View Count: 1284
| [2014-11-13 16:11:10] |
| User41512 - Posts: 58 |
With this feature if you set your threshold to X, and you also set it to show you a visual alert only, does it only provide a visual alert once per bar ?ie i have multiple numbers above my threshold but it only seems to highlight the first one. Also if a higher number subsequently comes out in the same bar, it does not highlight it. Can this be changed ? |
| [2014-11-13 17:53:32] |
A visual alert is not supported with a study and that cannot change.
