Date/Time: Mon, 26 Oct 2026 19:36:52 +0000
Simple way to add many SMAs
View Count: 1522
[2014-11-13 09:14:41]
User99526 - Posts: 5
Could you advise easy way to add 2000 SMA to chart?
Also I need change settings for each of them.
If I will be use MA study it will take a lot of time
I need change for each MA study
- Input data
- Length
- then go to "Subgraphs" tab and change color
Thank you
[2014-11-13 10:47:35]
Do you mean 2000 moving averages? That large number is not supported.
[2014-11-13 11:02:34]
Exactly 2000 moving averages. Why this is not supported?
Date Time Of Last Edit: 2014-11-13 19:15:45
[2014-11-13 18:26:11]
Actually, we made a mistake. There is no longer a limit on the number of studies that can be added. So you can add 2000 moving averages.
What you can do is configure the Moving Average study with some default settings so it is the same each time added. And then you can make whatever minor adjustments you need after that. Refer to:
Chart Studies: Using Custom Default Study Settings
