Date/Time: Sun, 22 Nov 2026 23:29:13 +0000
Is It Possible To Use Alert From Study To Color Bar?
View Count: 1243
[2014-11-13 01:26:37]
cmet - Posts: 747
Trying to find out if there's a way to use the alert formula from a Study to color a bar on the chart.
I have the alert formulas set up correctly and they work with an audio alert. The studies are located in Chart Region 2 and they do not use the high/low/last from the actual bars (in Chart Region 1).
For example: There's an alert that is true when stochastic momentum crosses above a moving average. These studies are in Chart Region 2. When the condition is true, I would like it to color the price bar a different color.
I can't figure out from the instructions for Color Bar Using Alert Condition how to do this.
Is this even possible?
Date Time Of Last Edit: 2014-11-13 01:31:22
[2014-11-13 02:56:29]
Sawtooth - Posts: 4362
Yes, it's possible. Move the formula to the Alerts tab of the Color Bar study, then modify the formula to include the ID# of the all studies it references, like this:
=CROSSOVER(ID1.SG1,ID2.SG1)
[2014-11-13 03:00:50]
cmet - Posts: 747
Ah man...thank you.
Big "duh" moment on that one.
Thanks again.
