Date/Time: Mon, 26 Oct 2026 19:39:06 +0000
HEIGHT OF CHART
View Count: 1272
| [2014-11-12 17:50:10] |
| tellerbe - Posts: 109 |
When I downlosd a new chart and place the cursor on price,I cannot get the height oh thr chart to change. Thanke, T. Ellerbee |
| [2014-11-12 18:45:05] |
We are not understanding this.
| [2014-11-13 16:49:38] |
When the cursor is placed over "price" and then left clicked and moved up or down, the length of the candles should get longer or shorter. This does not happen when I am installing a new chart. T.Ellerbee |
| [2014-11-13 19:08:30] |
Make sure Chart >>Logarithmic Scale is unchecked. Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#InteractiveScaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
