Date/Time: Sat, 07 Nov 2026 19:11:53 +0000
Currenex Trading
View Count: 1428
| [2014-11-12 07:51:52] |
| User78442 - Posts: 260 |
Does SC interface to Currenex? If so is it via FIX?
| [2014-11-12 08:05:38] |
Yes. Sierra Chart does support Currenex and the connection protocol is FIX.
| [2014-11-12 08:31:34] |
