Date/Time: Sat, 07 Nov 2026 19:11:54 +0000
Rectangle tool with Kumo cloud
View Count: 1548
| [2014-11-11 23:38:32] |
| BDS City Group LTD - Posts: 4 |
Hi, with the strategy I adopt I regularly use the Kumo cloud by incorporating the senkou span a and b on to my charts. I have found that when I use a tool such as the rectangle or circle to highlight something the shape disappears behind the Kumo cloud. How to I adjust the settings so that the shape stays at the front and is clearer in highlighting my desired area? Thanks |
| [2014-11-12 04:11:39] |
This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DisplayOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
