Date/Time: Mon, 30 Nov 2026 23:08:38 +0000
Parallel Lines Tool changed behaviour after update
View Count: 10
| [2026-11-30 22:44:22] |
| User629461 - Posts: 214 |
Before most recent update when drawing Parallel Lines, the anchor for the second line could be positioned using Auto Snap along any bar's OHLC point. After the update the Auto Snap doesn't work. Need to place the second line randomly on the chart then relocate it after its drawn to the desired location. Would also like to make a feature request: ability to draw additional lines at levels based on pointer location on the chart (not just at preset % levels) |
| [2026-11-30 22:52:31] |
| John - SC Support - Posts: 48679 |
We are not seeing an issue with this. When we draw a Parallel line and have the option for "Auto-Snap on Creation" enabled, then the second line tries to snap to the OHLC of the bar associated with the first anchor point. If you are referring to some other functionality, then we need to understand what is different from what you are expecting, as we are not seeing any changes in how this works. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
