Date/Time: Mon, 30 Nov 2026 21:32:27 +0000
Build 2800: blank Studies lists and loss of recorded ACSIL callbacks during historical rep
View Count: 5
| [2026-11-30 21:20:16] |
| User73472599 - Posts: 6 |
I would appreciate guidance on investigating this behaviour in Sierra Chart 2800, 64-bit Windows. We have not established whether the cause is Sierra Chart, our custom studies, their interaction or the environment. Setup - One historical 5000-volume chart. - Standard Heikin-Ashi followed by two custom ACSIL studies. - Single-chart replay at 1×, using Calculate At Every Tick/Trade. - Trade Simulation enabled, live order routing disabled and data service disconnected. Observed behaviour In the original session, recorded custom-study callbacks ceased while the UI remained responsive enough to accept Pause. Both Studies Available and Studies to Graph were blank. Cancelling and reopening the dialog with F6 did not restore them. A separate instrumented attempt reached its 60-minute wall-clock cap without a detected recurrence during monitoring. Replay then remained paused. A diagnostic latch intentionally prevented further collection work, but outer callback entry/exit recording continued. At a later closure check, both Studies lists were blank again. The retained outer counters showed completed final calls and no subsequent advance, despite later UI activity. This transition was not continuously monitored, so its timing and relationship to the blank dialog are unknown. Instrumentation and debugger attachment may have affected timing. Sierra Chart subsequently exited normally. Available evidence We retain three process snapshots: - The original late-failure snapshot, with limited memory coverage. - A post-cap full-memory snapshot, with the Studies-dialog state unverified. - A full-memory snapshot taken when the later blank dialog was visible. None contains a fault-time exception context. Exact executable/DLL identities, logs and callback diagnostic records are also available. Request for guidance Could you advise whether the existing snapshots can help determine: 1. Whether the chart’s study instances were still actively registered. 2. Whether their scheduling/update state explains the loss of recorded callbacks. 3. Whether Studies-dialog initialization or enumeration failed. If this cannot be determined from the snapshots, what supported diagnostic or minimal reproduction would you recommend? Please advise whether the exact build matters and whether you can review relevant material privately. No files are attached initially. We can provide the minimum relevant evidence on request, but will not publicly attach process dumps, account information or proprietary source. Thank you. |
