Date/Time: Sat, 28 Nov 2026 20:03:19 +0000
Denali real-time data stalls from Europe - packet loss on route Zayo -> 123.NET Detroit (6
View Count: 18
[2026-11-28 18:34:02]
User444809 - Posts: 1
Location: Eastern Switzerland (ISP RSN). Sierra Chart 2985 64-bit, data service "SC Data" / Denali, CME ES and NQ, Sim trading only. (Sierra Chart runs under Wine on Linux; all measurements below were taken at the TCP level of the operating system and do not depend on Sierra Chart.)
Problem: Since mid-November the DOM regularly freezes for 0.5 to 4 seconds, mostly around the RTH open. During these freezes another trading platform on the same PC (different data feed) keeps updating normally.
What I measured (details, charts and method are in the attached PDF):
1. Direct route (my ISP -> SwissIX -> Zayo -> 123.NET Detroit): 8.3% (ds32, 24 Nov) and 13.1% (ds7) of the incoming TCP segments of the Denali real-time connection arrive out of order, i.e. after a packet loss. At 120 ms RTT, each loss stalls the data stream for about 0.5 to 1 second. 24 Nov 08:30-08:39 CT: 12 DOM freezes of 0.6 to 1.1 s. 23 Nov 08:30:00-08:30:35 CT: 6 freezes of 2.6 to 4.2 s.
2. mtr from my PC to ds32 (600 probes each, 24 Nov afternoon, both files attached):
- ICMP: 0% loss on all hops up to the Zayo handoff 64.124.32.66 (including my ISP, hops 1-5), then 0.8% at 67.214.125.193 and 1.0% at 69.39.70.248. The loss continues to the end host, so it is not just ICMP rate limiting at a router.
- TCP to port 10048: the worst round-trip time is 165 ms up to 64.124.32.66, but 1.17-1.18 s from 67.214.125.193 onwards. That is a probe that was lost and resent by TCP after 1 second.
Both point to the segment after the Zayo handoff. The decisive measurement is still point 1 (TCP reordering on the real data connection).
3. Same PC, same settings, only routed through a VPN exit in Detroit (25 Nov, server 69.39.70.254): 2.2% out of order over the whole session and 0.2% in the opening minute. No DOM freeze from 08:29:27 to 08:34:14 CT, and only 3 freezes (0.5 to 0.8 s) between 08:30 and 08:39 CT. Through a Chicago exit: 3.1%. The RTT is the same as on the direct route (median 122 ms).
4. On 24 Nov the server closed the real-time connection twice: 08:44:15 CT (ds32, 69.39.70.248:10048) and 08:45:23 CT (ds32-2, 69.39.70.249:443), both "Socket gracefully closed by remote side". The Message Log is attached.
Ruled out on my side: CPU (the Sierra Chart main thread is idle during the freezes), network card (0 errors and 0 drops), loss on my ISP's hops, and the PC clock (NTP synchronized, offset about 1 ms).
Questions:
1. Could you check the path or peering between Zayo (64.124.32.66) and your Detroit network (67.214.125.193 / 69.39.70.x) for packet loss in traffic coming from Europe?
2. Is there a Denali server or route you recommend for users in Europe?
3. Do your server logs show why the connection was closed on 24 Nov at 08:44:15 and 08:45:23 CT?
Attached: PDF report, Message Log of 24 Nov, mtr outputs (direct and via VPN), raw ss and ping logs.
Thank you.
Daniel
Private File
