Date/Time: Sat, 28 Nov 2026 15:38:39 +0000
December 2026 Required Update – Flex MA Study and DLL Compatibility Concerns
View Count: 38
[2026-11-28 12:29:34]
User696540 - Posts: 39
I am contacting you regarding the September 3, 2026 technical notice concerning the required Sierra Chart update in December 2026.
I currently have three separate Sierra Chart installations:
Apex/Rithmic – Version 2939
Rithmic – Version 2913
AMP/Teton – Version 2919
All three installations are currently functioning properly.
However, during an attempted upgrade in October, I encountered significant compatibility problems involving the Flex MA study and its associated DLL files. I rely extensively on the Flex MA study, particularly its cloud display, throughout my chartbooks.
During the troubleshooting and upgrade process, which included installing version 2975, I encountered the following errors:
SierraChartStudies.dll requires version 2969 or higher.
Failed to get the function address for scsf_MAs in UserContributedStudies.dll.
Windows error code 127 – The specified procedure could not be found.
Sierra Chart Support previously indicated that ACSIL changes in version 2972 and higher required custom studies to be updated or recompiled.
I was ultimately able to restore normal functionality by returning to version 2939 and restoring the compatible DLL files from August 13, 2026.
With the mandatory December update approaching, I would appreciate clarification on the following:
What is the minimum Sierra Chart version that will satisfy the December 2026 market data feed changes?
Will this minimum version requirement apply to both Rithmic and Teton connections?
Is the Flex MA study, including its cloud functionality, compatible with the current Sierra Chart release?
Is an updated, compatible version of UserContributedStudies.dll containing the scsf_MAs function available?
If not, is it possible for Sierra Chart Engineering to update or recompile this study so that it will remain functional following the mandatory December upgrade?
What upgrade procedure would you recommend to preserve my existing chartbooks, study configurations and Flex MA functionality?
I would prefer to resolve these compatibility issues before the mandatory update rather than risk losing functionality in my trading installations.
Thank you for your assistance.
