Date/Time: Fri, 27 Nov 2026 15:55:55 +0000
Login Error: Connection Closed before a valid response received
View Count: 8
| [2026-11-27 15:23:36] |
| User100081 - Posts: 23 |
Hi, 18yr SC user, first time problem logging in, pop up said "Login Error: Connection Closed before a valid response received. Failed to read incoming decrypted data from the incoming binary I/O stream. Certificate verify failed." Updated from v2895 to 2896 on 11/25 but had no problems. Using Win 11 via Parallels, rolled back to previous Windows snapshot, still failed to login.
