Date/Time: Wed, 25 Nov 2026 19:43:36 +0000
I can't place trades and my account CashBalance suddenly becomes zero
View Count: 47
| [2026-11-25 17:17:58] |
| PabloMalo - Posts: 8 |
I have five LucidTrading Funded accounts, using Sierra Chart with Denali Feed Data, and just a few days ago I was able to place trades normally without any issue. But today suddenly I can't. Right now, every time I try to place a trade or entry, nothing happens. Doesn't matter whether it's a Buy limit Order or Sell Limit Order. The order simply isn't placed. And then I check my CashBlance for my five accounts and it's zero (even though it's not zero!!!). The strange thing is, as soon as I open Sierra Chart, my Cashbalance for the five accounts is a positive number (in this case 50001), but the moment I place the first entry, that CashBalance suddenly disappears and becomes zero, and it stays that way. I've checked my internet connection, I've tried closing and opening Sierra Chart multiple times, and I've also downloaded the current Sierra Chart version. It still doesn't work. I attach here some screenshots to illustrate what I'm talking about. |
Private File |
| [2026-11-25 17:56:44] |
| John - SC Support - Posts: 48658 |
After you try to place a trade, please get us your "Trade Service Log" by following these instructions: Support Board Posting Information: Providing Lines From Trade Service Log For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-11-25 18:03:29] |
This is the error message for each of the five accounts (I always copytrade from one account to all the others) ---> Rithmic Direct - DTC (Order Reject). Info: Rejected at RMS - Total buy quantity of contract would exceed its limit.
| [2026-11-25 18:06:29] |
Though to be honest, after playing around for a little while longer, I've realized I accidentally turned on the option of Quantity 3, instead of Quantity 1, before I started placing trade orders. I suspect that may have been the root cause. Can you confirm? |
| [2026-11-25 18:15:25] |
The message is coming from Rithmic, and is stating that you are trying to buy for a quantity greater than what is allowed for your account. So if you are trying to enter a quantity of 3 by accident, and your account is set to only allow 1, then this would be the reason for what you are seeing. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
