Date/Time: Wed, 25 Nov 2026 19:43:36 +0000
Teton CME Order Routing Problem 2nd Instance
View Count: 45
| [2026-11-25 16:56:14] |
| Lucas Muench - Posts: 28 |
Hello guys, here is what happened today: Introdocution and settings: For the first time since a longer time periode I was trading a personal live account. Stage 5 with Teton Order Routing. I am trading from Thailand. I was using 2nd Instance to execute. On the first instance I set "high compression" , 300ms remote buffer and d45.sierracharts.con as CME Exchange Data Feed Server Adress and Port Override. On the 2nd instance I forgot to set these settings , so it was all Standart and no server override. What happened was I executed Market on MES , then the order with brackets got stuck on the chart for what looked like 8-10 seconds. Cancel didnt work. After these several seconds the order filled market and I immidately tried to flatten which also was delayed maybe 3 seconds. I am aware that I forgot to set instance 2 like I setup instance 1, still this was scary. Internet speed overall is very fast and stable. My questions are: Did my different settings cause this problem? Is there any reported problems with trading CME products overall or specifically with Teton from South East Asia? Is there anything else I need to check? I will attach the settings and a trade activity log. I already contacted stage 5 and according to them the log looks normal. Thanks for the help |
| [2026-11-25 17:54:46] |
| John - SC Support - Posts: 48658 |
The first thing to keep in mind is that the connetivity to the exchange does not change with the different settings. You are still having to get your orders to Chicago, IL in the U.S. for the orders. So any Internet connectivity issue between your location and the servers in Chicago will create an issue. Most likely, this is what occurred. We really need to see your "Trade >> Trade Service Log" from when this occurred. If you have not restarted your Sierra Chart, then please get us that log by following these instructions: Support Board Posting Information: Providing Lines From Trade Service Log We would also like to get your Message Log from that same time by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Please let us know the time of the incident in the Global Time Zone set for your software. If you have restarted your software since the incident, then the logs will have been cleared, so there is no point in posting them. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-11-25 18:07:13] |
I have restarted it since then . I will try again tomorrow , if it appears again, I will send it to you . Thanks !
| [2026-11-25 18:16:13] |
Keep in mind that Tomorrow is the US Thanksgiving Holiday, so the CME Group has odd hours.
