Date/Time: Tue, 24 Nov 2026 15:42:42 +0000
Market by Order data on ESZ26: any filtering besides the 3-contract minimum?
View Count: 8
[2026-11-24 15:09:28]
User758074 - Posts: 2
Sierra Chart version 2985, Denali real-time data. The Market Orders Data connection logs in and starts market orders updates for ESZ26-CME, NQZ26-CME, MESZ26-CME, MNQZ26-CME and MBTX26-CME. Minimum Market by Order Quantity has not been changed (the log shows MinimumMarketByOrderQuantity: 0).
I understand from the Market by Order Data documentation that only orders with a quantity of 3 or more are sent, and that the data is not a complete list of the orders at each price.
I wrote a read-only ACSIL study that every 10 seconds reads the top 10 depth levels on each side (sc.GetBidMarketDepthEntryAtLevel / sc.GetAskMarketDepthEntryAtLevel) and, for each level price, the market orders from sc.GetBidMarketLimitOrdersForPrice / sc.GetAskMarketLimitOrdersForPrice. It logs only counts and ratios. Observations (times are New York):
1. The smallest order returned is always 3 contracts, on all five futures, which matches the documentation.
2. For ESZ26, the market orders are about 6-7% of the exchange order count (the NumOrders field of the depth levels) overnight, and about 1.5% during 09:30-10:00. On 2026-11-24 the overnight level held until about 07:00 and fell to about 2% after 08:10. For comparison, MBTX26 is 37-72% and MESZ26 8-28% over the same periods.
3. The ES order sizes are small: depth quantity divided by NumOrders over the top 10 levels is only 1.2-1.3 contracts. So a low share is not surprising by itself.
4. As a consistency check, at any level where quantity > 2 x NumOrders there must be at least one order of 3 or more. On ES, at nearly all such levels the market orders list was not empty (0 of 224 levels empty overnight on 2026-11-23/24, 0 of 238 on 2026-11-24 07:00-08:30, 21 of 617 on 2026-11-23 11:10-16:00). On MBT the same check gives 1-5%.
So we found nothing that contradicts the 3-contract rule. But the check only applies to the 1-5% of levels where quantity > 2 x NumOrders, and we cannot tell anything about the other levels.
Questions:
1. Apart from the 3-contract minimum, is any other filtering, limiting or sampling applied to the Market by Order data for CME equity index futures such as ES? For example, a maximum number of orders per price level, a limited number of price levels, or reduced updates during busy periods.
2. Does the NumOrders field of the market depth data for ES (CME market by price) include implied orders? Does the depth quantity include implied quantity?
3. On 2026-11-23 I ran the same study on six CME options on futures: E4AX26 P7125, Q4AX26 P26000, MESZ26 P7125, MNQZ26 P26000, WMX26 P62000 and W4AX26 P62000. Five of them had live quotes with up to 3 depth levels per side, and the average order size was well above 3 contracts, but no market orders were returned in any sample overnight or during the day. The Message Log shows "Starting market orders updates for: <option symbol>" from the main Denali Data Feed connection, not from the Denali Data Feed (Market Orders Data) connection. Is Market by Order data available for CME options on futures?
Thank you.
