Date/Time: Mon, 23 Nov 2026 23:54:37 +0000
Unable to place sanding order
View Count: 14
| [2026-11-23 22:04:35] |
| User255709 - Posts: 6 |
Hello, when I try to place a standing order, the lines on the chart flash on and then off. When I check trade service log it says: trade order error - rate increases position - liquidation mode only
| [2026-11-23 22:17:53] |
| John - SC Support - Posts: 48633 |
Your account is in Liquidation Mode, which means that there is an issue with your account, so all you can do is decrease your positions until you are flat in the market. You can not open new positions. You need to talk to your broker about your account to get further information on why you were put in liquidation mode. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
