Date/Time: Mon, 23 Nov 2026 21:33:55 +0000
Volume by Price Values Coloring
View Count: 14
| [2026-11-23 19:58:23] |
| User528002 - Posts: 26 |
Regarding the Volume By Price Study, would it be possible to make it so that when "Display Data in Chart Values Window" is set to Yes, and "Show Chart Values on Profile" is set to something other than do not show, that in the subgraph we can have the option to display different colors for whether values are positive or negative. So for instance, the only chart values I look at are Ask Volume minus Bid Volume and Imbalance Percentage. When one of those values is negative I'd like to be able to paint it red and when one of the values is positive I'd like to be able to paint it blue. And this would work if say AV-BV were minus 2235 so it would paint -2235 in red, and then at the same time is I% were +13.65 it would paint +13.65 in blue. Small detail. Would be of great help. Thank you for considering and wishing you and yours a very Happy Thanksgiving. |
| [2026-11-23 20:00:08] |
| John - SC Support - Posts: 48625 |
Are you wanting the values that are displayed with the profile itself to have +/- coloring, or are you asking for the values displayed in the Tool Values Window? Or both?
