Date/Time: Mon, 23 Nov 2026 21:33:58 +0000
Depth of Market issues
View Count: 18
[2026-11-23 17:37:07]
tylerxtorres - Posts: 1
i purchased some chartbooks and was having trouble with my heatmap and cumulative delta loading properly. They told me to reach out to you guys directly as it seems like its a data feed issue. The historical market depth doesn't show anything at all and my cvd is patchy
[2026-11-23 17:42:14]
John - SC Support - Posts: 48625
We want to point out that you are setup to get data from us (including the Market Depth data) for the CME exchange of the CME Group. So if you are trying to get Market Depth data for symbols traded on a different exchange, then this could be your issue.
In order to download any missing historical Market Depth data, refer to the following (note Step #8 in particular for how to force a download from a specific point in time):
Market Depth Historical Graph: Downloading Of Historical Market Depth Data
There should not be any issue with the Cumulative Delta, particularly for CME exchange data, as this is based on actual traded information, not the Market Depth. We wonder if you may be missing data at those points where the Cumulative Delta looks odd. If this is the case, then refer to the following:
Otherwise, we would need to see an image of your chart that has the Cumulative Delta on it. Follow these instructions to get us an image:
