Date/Time: Sun, 22 Nov 2026 21:11:00 +0000
Tool Settings >> change to HAND does not play nice with the DOM
View Count: 14
| [2026-11-22 19:24:49] |
| User719512 - Posts: 545 |
If you set Tool Settings to HAND (see image for the 3 settings), Sierra does not let you cancel the Horizontal Line for example with a Right Click. You have to actually set the Horizontal Line for example, choose Ptr or Chart Val, select it, and use Del key to delete it. I believe this is because from what I see is that the Hand tool cannot be selected on a DOM where it is possible to put Horizontal Lines in the Labels column. I have also seen related strangeness with these settings for how Sierra behaves when you use Chart Val or Hand on a chart, then click a DOM to active window and sometimes you see the Hand mouse pointer when the control bar has Chart Val depressed which usually gives the plus-sign/cross mouse pointer. My current workaround is to not use HAND on the Tool Settings and instead use POINTER, but then that breaks being able to scroll my chart without reselecting HAND. So I have to choose...poor workflow on charts, or getting strange behavior on a DOM if I accidentally click while a tool is selected. Neither are desired. Hoping you can fix. Is there any reason you cannot allow HAND on the DOM? Unsure if this is by design, an oversight, or if allowing it has side effects. |
