Date/Time: Mon, 23 Nov 2026 16:01:21 +0000
[User Discussion] - New third-party study: Pulling and Stacking Indicator
View Count: 17
| [2026-11-21 19:16:42] |
| Sigmantra Scott - Posts: 1 |
Hi there, I'm Scott from the Sigmantra team. We've released our Pulling & Stacking Indicator 3.0 as a custom study for Sierra Chart. I'm posting here to let Sierra Chart users know it exists and to answer questions. Who we are Sigmantra was established in 2022 (our former name was Engineered). We implement a user and research-centric product development practice to build the Pulling & Stacking Indicator. What it does The study reads the order book and the trades as they happen. Every resting order stacked or pulled, and every aggressive execution, goes into one normalized signal, measured in standard deviations. It is meant to show when order flow is unusual and which side is behind it. What you see In addition to performing research into what we have found to be core order flow metrics, much of our product development effort has been focused on presenting data in a way that is cognitively helpful based on user feedback. The design intent behind the indicator is to foster focus on the data that matters, without displaying an overwhelming amount of information for traders that have adopted their own trading methodologies and systems. The study draws its lines in its own region under the price chart. There are two line modes. Flow mode (the default) - Total Flow: passive order book changes plus aggressive executions. This is the headline line. - Passive Flow: resting liquidity stacked (+) or pulled (-) across the nearest price levels of the book, 10 levels per side by default. - Aggressive Flow: executed volume delta, buys minus sells. This is the cumulative delta most order flow traders already know. - Placement Flow (hidden by default): Passive Flow minus Aggressive Flow. A trade removes resting size, so Passive Flow already contains executions. Placement Flow takes them out, leaving only the orders that were placed and cancelled. Total Flow = Passive Flow + Aggressive Flow, exactly, on every event. Readings are not smoothed or filtered. Buy / Sell mode - Buy Line: resting liquidity stacked or pulled on the bid side. - Sell Line: the same on the ask side. - Delta Line (optional): Buy Line minus Sell Line. This mode shows the two sides of the book separately. Both lines rising is two-sided stacking, where the net can be near zero although the book is busy. One line rising while the other stays flat is one-sided pressure. The pair can be shown with executions (the default) or as placement only, where each trade is added back to the side it consumed. How significance is measured Raw flow in contracts cannot be compared between symbols, sessions or volatility regimes. The study therefore measures each line against its own recent behaviour and reports the result in standard deviations (sigma). - Each line is a rolling sum over a window of 2, 3, 5 or 10 minutes. The default primary window is 5 minutes. - The line is then compared with its own mean and variability over a lookback of 5 times that window. With the 5 minute window, the lookback is 25 minutes. With the 10 minute window, it is 50 minutes. - A reading such as "Total Flow +4.2 sigma (5m)" means the 5 minute flow is 4.2 standard deviations above its norm of the last 25 minutes. - Because every reading is scaled to the instrument's own recent variability, a sigma value means the same thing on different symbols and in different sessions. The Resistance and Support band - Two lines drawn at plus and minus 3 standard deviations of the line you read, over the same lookback of 5 times the window. - In Flow mode the band belongs to one line, the core line, which you choose: Total Flow (default), Passive Flow or Placement Flow. The band is sized from that line's own variability and is never borrowed from another line. - In Buy / Sell mode the band is built from the two plotted lines. - A line reaching the band is statistically stretched compared with its own recent behaviour. It is context, not a trade call. The level depth (10), the band width (3 standard deviations) and the lookback multiplier (5) are settings and can be changed. Arrows on the price chart An arrow marks the bar where the line you read crossed outside its band: an up arrow below the bar for a bullish reading, a down arrow above the bar for a bearish one. An arrow is a prompt to look at the flow lines, not an instruction to buy or sell. The console window One window for all your charts, with a tile per instrument: - A single view for order flow activity across multiple instruments, providing a single area for understanding broad market context without having to switch between charts. - The current sigma reading and the line it refers to. - The four windows side by side (2, 3, 5 and 10 minutes), each with its own sigma value. A spike in the 2 minute window that the 10 minute window ignores is a burst. All four leaning the same way is sustained flow. - Absorption or initiative: absorption when the book and the tape disagree (for example the book stacking bids while the tape sells into them), initiative when they lean the same way. - A log of events, and optional alerts with a threshold you set. Warm-up The order book has no history, so the lines start from the moment the study is added. With the default settings the band needs about 25 minutes of data before it is drawn in full, and the study shows that it is warming up until then. What it needs - Market depth data for the symbol, since pulling and stacking is measured on the order book. - A subscription and licence key from sigmantra.com. A seven minute overview recorded on Sierra Chart: https://www.youtube.com/watch?v=AjCqqiRxpog Details and the install guide: https://sigmantra.com/for/sierra-chart/ Full documentation: https://sigmantra.com/docs?platform=sierra-chart It is an analytical tool. It does not give trade recommendations, and nothing it displays is a signal to buy or sell. Futures trading involves substantial risk and is not suitable for every investor. Questions and feedback are welcome, in this thread or at contact@sigmantra.com. I'm always amazed at the quality of feedback we receive. We consider all feedback as an opportunity to improve our product. Thank you! Scott Date Time Of Last Edit: 2026-11-21 19:17:55
