Date/Time: Sat, 21 Nov 2026 17:10:46 +0000
TPO_VbP Tick increment
View Count: 11
[2026-11-21 16:23:05]
User583603 - Posts: 3
Hello. I know this has been brought up before, and you’ve mentioned that it’s not straightforward to separate the tick increments for TPO and VbP. However, perhaps it might be possible to display the Value Area and VPOC based on a 1-tick calculation. When I use the Daily OHLC study on a TPO chart, the high is displayed correctly, even with a 10-tick increment.
imageTPO_VbP_10_tick_increment.png / V - Attached On 2026-11-21 16:17:23 UTC - Size: 87.69 KB - 1 views
imageTPO_VbP_1tick_increment.png / V - Attached On 2026-11-21 16:17:37 UTC - Size: 71.15 KB - 2 views
imageTPO_DailyOHLC_10_tick_increment.png / V - Attached On 2026-11-21 16:17:47 UTC - Size: 100.76 KB - 2 views
