Date/Time: Mon, 19 Oct 2026 13:36:18 +0000
Is that possible to copy drawing from another chartbook?
View Count: 1254
| [2014-11-11 13:52:45] |
| User17064 - Posts: 70 |
I know SC has function to copy chart drawing from one chart.But it must be in one chartbook. Is that possible to copy drawing from another chartbook? |
| [2014-11-11 17:15:56] |
| TradingMarketProfile - Posts: 120 |
yes you can chartbook name:chart number |
| [2014-11-11 18:38:35] |
Yes. Refer to the documentation for this here: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
