Date/Time: Thu, 19 Nov 2026 19:00:43 +0000
frozen orders
View Count: 20
| [2026-11-19 17:19:24] |
| User93731 - Posts: 85 |
Dear Sierra Chart Support: My Prop firm, Bulenox which uses the Rithmic data feed, “confirmed that the orders displayed as non-responsive in Sierra Chart on my account were received and executed on the Rithmic side. Sierra Chart did not receive the order acknowledgments and subsequently timed out the orders. In contrast, the orders actually remained active on the server, which resulted in the position being auto-liquidated”. It asked me to contact Sierra Chart Support and provide them with the order history and logs for further review of why the order acknowledgments were not received and the cancellation attempts did not reach the server. I know the support for Rithmic is limited, and I am wondering if applying the “Easy Solution” - opening an account at Stage 5 to connect to Teton Order Routing & Denali Data at Sierra Chart will solve this problem. I have attached the Trade Activity Log as your reference to this message. My frozen orders took place from 06:01 to 06:15 on 11/16/2026, so you could narrow your review to this attached file. Best, and thank you for your time. |
| [2026-11-19 17:31:24] |
| John - SC Support - Posts: 48593 |
There is nothing for us to review. The issue you had was due to Rithmic being non-responsive at that time. This is completely and wholly a Rithmic issue and has nothing to do with Sierra Chart. We want to point out that the interface between Sierra Chart and Rithmic is owned by Rithmic. We have nothing to do with it, nor is there anything we can do to fix it. We have informed Rithmic of these issues multiple times. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
