Date/Time: Thu, 19 Nov 2026 19:00:43 +0000
New Instance: is MarketDepthData copied on first start? Back testing in a sub instance
View Count: 13
| [2026-11-19 17:16:59] |
| User758074 - Posts: 1 |
Version 2982, Windows Server 2025. The main instance records market depth continuously (the MarketDepthData folder is about 168 GB) and the disk has about 138 GB free. 1. When a sub instance is started for the first time with File >> New Instance, is the Data\MarketDepthData folder copied into SierraChartInstance_2? Is the Backups folder copied? 2. On its first start, does the sub instance automatically open the Chartbooks that are open in the main instance? Is there a way to start it with no Chartbooks open? 3. In a sub instance, does a Bar Based Back Test or a Chart Replay require disconnecting the sub instance from its data feed (DTC - Sub Instance)? If so, does that disconnection affect the main instance's data feed connection or its market depth recording in any way? 4. Do Symbol Settings with "DTC Server Disallow Market Data" set to Yes affect a sub instance's access to that symbol's data? |
