Date/Time: Thu, 19 Nov 2026 17:16:14 +0000
ACSIL study exporting per-trade results from historical NQ tick data
View Count: 29
[2026-11-19 16:13:13]
User634249 - Posts: 2
Before subscribing, I'd like written confirmation that the following is permitted. It's similar to the case you approved in thread 107997, but larger.
Plan: Service Package 3 for one month, downloading historical NQ tick-by-tick data for 2016 to 2023 through the Sierra Chart Historical Data Service. No real-time data, no trading, no funded futures account.
A custom ACSIL study, running inside Sierra Chart, reads a CSV of about 2,800 of my own backtest trade entries. For each entry it writes one row with an ID and 8 numbers:
- the entry bar's delta (ask volume minus bid volume)
- cumulative delta from 09:30 New York time to that bar's close
- the 80th percentile of the delta at the same bar time over the previous 20 sessions, and how many sessions that used
- the same bar delta and cumulative delta, estimated from whether each 1-second bar, and separately each 1-minute bar, closed up or down
No prices, volumes, bars, tick data or other time series leave Sierra Chart, and no other program reads your data files.
1. Is exporting these per-trade values permitted under your Data License?
2. May I keep and use the exported values for my own research after my subscription ends?
3. Does Package 3 include CME tick-by-tick history with bid/ask volume for NQ for 2016 to 2023?
4. Are any exchange fees due for this historical-only use?
5. Does this permission also hold under your CME agreement, with no separate license needed from me?
Thank you.
[2026-11-19 17:04:59]
John - SC Support - Posts: 48592
1. Yes.
2. Yes.
3. Yes.
4. No.
5. Yes.
[2026-11-19 17:11:15]
Thank you. One follow-up: later I'll run the same study, exporting the same 8 numbers per entry, on my entries from 2024 to today. Does the same answer apply to those years?
[2026-11-19 17:15:44]
The same answers apply if you are getting historical data (anything more than 10 minutes prior to the current time)
If you need real-time data, then you would have to setup and pay for the exchange data.
