Date/Time: Thu, 19 Nov 2026 17:16:14 +0000
Alert Manager Not Acting Properly
View Count: 20
| [2026-11-19 15:39:23] |
| User708541 - Posts: 214 |
on only one of my Chartbooks, when I select Window > Alert Manager, the menu item shows a checkmark indicating that the Alert Manager is open. However, the window is nowhere to be found. Clicking the menu item again does not remove the checkmark. The Alert Manager keyboard shortcut does not resolve the issue. The Alert Manager does not appear when using Alt + Tab. Restarting Sierra Chart does not resolve the issue. Is there a way to reset the position and visibility of the Alert Manager independently, without using Window > Reset Windows? I would prefer not to reset the window positions of my existing workspace. The screenshot shows the checkmark that is not acting as a toggle. |
| [2026-11-19 16:00:51] |
| John - SC Support - Posts: 48592 |
The Alert Manager will not show up when using "Alt-Tab" as it is not a separate window that is managed by the Operating System. The only option is "Reset Windows". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
