Date/Time: Thu, 19 Nov 2026 17:16:14 +0000
Need help with setting DOM Alert
View Count: 21
| [2026-11-19 15:05:57] |
| User246578 - Posts: 85 |
Trying to set an Alert using DOM Alert Steps: 1. Chart 2. Chart Settings 3. Alert 4. Setting Alert Condition to =SG1 > 99 It should work if LastSize > 99, right? But it's not working. Why? What am I doing wrong here? Thank you |
| [2026-11-19 15:51:54] |
| John - SC Support - Posts: 48592 |
From what you have stated, SG1 in this case would refer to the first subgraph of the Main Price Graph, so it would be the Open of the most recent bar. What exactly are you wanting for your alert? What do you mean by "LastSize"? Are you referring to the total volume of the most recent bar, or the quantity of the most recent trade? or something else? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
