Date/Time: Thu, 19 Nov 2026 14:55:55 +0000
Enhancement request: Reward/Risk Tool
View Count: 32
| [2026-11-19 14:18:04] |
| User174736 - Posts: 6 |
Hello, would be great if you could implement the following optional enhancements to the R/R tool: 1. Add an Offset (in ticks) to the Stop ["Stop Offset"] 2. Add an Offset (in ticks) to the Target(s) ["Target Offset"] 3. Ability to click and adjust the additional Target(s) - e.g., the Target Multiplier for Target 2, 3 and 4 can still be used as initial targets but this enhancement would allow for the ability to quickly adjust any of these if desired. Suggested implmentation for the offsets: A positive number moves stop/target further away from the market while a negative number moves it closer. If zero, no offset is applied. Example: Let's assume we have a swing-high in the ES at 7500.00 and that we want our stop above this extreme. We have a 'Stop Offset' of 6 ticks configured and upon snapping the Stop to the high - it would automatically adjust to 7501.50. Let's also assume the prior swing-low is 7400.00 and we want our Target to be just below this extreme. We have a 'Target Offset' of 1 tick configured and upon snapping the Target to the low - it would automatically adjust to 7399.75 Thanks in advance. |
| [2026-11-19 14:33:16] |
| ForgivingComputers.com - Posts: 1254 |
This is available now with my Futures Reward:Risk Position Sizer: https://forgivingcomputers.com/product/risk-based-futures-position-sizer/ Up to 5 targets based on multiples of the drawn Stop, or the Target. Optional Snap-To OHLC of any bar with adjustable sensitivity and offsets for Stop, Entry, or Target. Automatic Order quantity based on % Available Account Balance or $ Amount. including Commission. Supports x86 and ARM processors. Date Time Of Last Edit: 2026-11-19 14:39:04
| [2026-11-19 14:50:27] |
| John - SC Support - Posts: 48586 |
We have noted this as a Feature Request.
