Date/Time: Wed, 18 Nov 2026 15:30:02 +0000
Reload All Charts Only Reloads Active Chartbook – Need to Reload All Open Chartbo
View Count: 15
[2026-11-18 13:49:05]
User877866 - Posts: 34
Hello Sierra Chart Support,
I'm experiencing an issue with the Reload All Charts function.
I have multiple Chartbooks open simultaneously, organized into separate tabs:
MainWatch
A-B
C-D
E-F
G-I
J-R
M-N
O-P
Q-S
S-Z
When I use Alt+R or manually select Edit → Reload All Charts, Sierra Chart appears to reload only the currently active Chartbook rather than all charts across every open Chartbook.
What I'm trying to accomplish:
I want to reload historical data and recalculate studies across every chart in all open Chartbooks without having to manually switch between each tab.
Questions:
Is there a setting that allows Reload All Charts to apply to every open Chartbook?
Is there a separate command to force a historical data reload across all open Chartbooks?
Is there a way to automate a complete reload and recalculation of all charts across all Chartbooks?
I would appreciate clarification on the intended behavior and the recommended solution.
Thank you.
[2026-11-18 13:57:58]
I created a solution to automate scheduled chart-data reloads in Sierra Chart.
I built a custom ACSIL study in C++ that uses `sc.FlagToReloadChartData = 1` to trigger the same operation as **Chart → Reload and Recalculate**. It has configurable time slots, so I can schedule reloads throughout the trading day.
I installed the study across my charts, allowing each chart to reload automatically at the specified times without manually opening each Chartbook and pressing Alt+R.
It isn't a direct execution of the global **Edit → Reload All Charts** command, but it accomplishes the scheduled reload across all charts individually.
