Date/Time: Wed, 18 Nov 2026 12:31:52 +0000
How do I get a quoteboard up
View Count: 5
[2026-11-18 12:01:53]
midas59 - Posts: 22
Hi
I am running SC 2972
In previous versions I had a simple quote board showing multiple instruments, and volume. To open this I simply went File >> New Quote Board, and there was the ability to select and open a previously saved quote board.
In the current SC version this does not seem to be available.
I created a new quoteboard, but I cannot reopen it.
This quoteboard is showing in SierraChart\Data as DailyVols.SymbolList as file type All Files(".")
If I select this file and hit Open, nothing actually opens or shows on screen.
If I go to the CW icon at the screen header the file doesnt show in the dropdown.
Please advise how I can create a simple quoteboard, and refer to easily
Thank you
