Date/Time: Tue, 17 Nov 2026 22:33:18 +0000
GDIprobe vs SC version
View Count: 9
| [2026-11-17 21:50:00] |
| Jerome70 - Posts: 5 |
Hello, i programmed a custom studio using GDI instruction set on my laptop (SC 2982) - it worked fine - Then I wanted to install it on my main pc computer by compiling the same original .cpp (Version of SC on my computer is 2947) The build is ok but nothing happened on SC running this Custom Studie. (no errors) I did a test with a very basic chart and a simple study call "GDIprobe". It suppose to draw a yellow square box on the graph. It worked fine on SC 2982 But nothing happened on SC 2947 Do you know why ? (sorry for my very scolar english) Jerome |
