Date/Time: Mon, 16 Nov 2026 16:21:03 +0000
Change background colour of the Chart Values Window?
View Count: 20
[2026-11-16 13:55:40]
HeyUgly - Posts: 289
I cant seem to find the setting. Its defaulting to a grey color, i want black as i cannot read the text at all on the columns of the chart values window. Where in the color settings of general settings is this setting located for the chart values window?? - I have 20 columns of data on the chart values window i cannot read because of the background color of it. Thanks!
[2026-11-16 16:08:25]
John - SC Support - Posts: 48539
Refer to the following for the Chart Values Window background:
Graphics Settings: Chart Values Window Background Color
If you are changing this item and it is not having an effect, then you are changing the Global option when you are setup to use the Chart specific option, or vice versa. Refer to the following:
Graphics Settings: Using Different Color and Graphics Settings for Specific Charts
