Date/Time: Fri, 13 Nov 2026 15:17:10 +0000
Graphic Settings
View Count: 76
| [2026-11-12 12:21:19] |
| User688525 - Posts: 403 |
Hello Sierra, A few screenshots are attached. 1. Can the windows border width be adjusted? 2. Can the color of the top bar (next to "Help") be changed? 3. Can the divider color between charts be changed? Thank you |
Private File Private File Private File |
| [2026-11-12 15:24:35] |
| User719512 - Posts: 541 |
This post might answer one of your questions: New MDI Window system Request : Allow users to configure border thickness | Post: 432055 |
| [2026-11-12 15:48:17] |
| John - SC Support - Posts: 48520 |
1. As User719512 points out, that is an Operating System item. 2. The main window Title Bar size is also an Operating System item. You can change the size of the Title Bar for individual charts that are contained within the main Sierra Chart window. Refer to the following setting and the one below it: Graphics Settings: Window Title Bar 3. We do not understand what you mean by the "Divider Color" in this case. The tabs have specific coloring depending on whether they are the active or inactive tab including a separate border color. Refer to the following setting and the 5 below it: Graphics Settings: Chart Selected Tab Color For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-11-12 23:53:26] |
Hello Sierra and User719512, These are all Windows Operating System items. Thank you |
