Date/Time: Wed, 11 Nov 2026 18:38:02 +0000
Volume by Price: (SG6) Colors Bleed Through Value Area (SG20) ln:50 Has no effect
View Count: 17
[2026-11-11 16:27:17]
User708541 - Posts: 210
With SC in the quest for constant improvement:
In the Volume by Price (VbP) study, Can SG20 be updated so that it renders across the full pixel height of each volume bar, without changing the underlying volume profile resolution?
On NQ at a normal viewing resolution, the Value Area is completely dominated by the regular volume bars. I found a post where you say that SG20 is painted over the volume bars, but at normal resolutions the value are disappears.
I'd prefer to not have to resort to increasing the "Ticks Per Volume Bar" as a work around.
Thank you in advance
[2026-11-11 18:19:08]
John - SC Support - Posts: 48499
If you are using the default colors, and the issue is that you are not able to see the Value Area as a different color, then this is due to the particular colors that are used by default.
In particular, when the profile bars are very close together, then you typically do not see the actual bar coloring, but are seeing the outline color. By default, the outline color of the bars, and the outline color of the Value Area are the same, so you just see the gray. See our attached image named "Before.png".
If you change the color of the outline for the "regular" bars (i.e. the "Volume Bar Outline and Fill Colors" (SG8)) to be something different, then those bars will become obvious. See the attached image named "After.png".
If not the above, then we need more information on what exactly you are referring to.
imageBefore.png / V - Attached On 2026-11-11 18:18:46 UTC - Size: 52.39 KB - 2 views
imageAfter.png / V - Attached On 2026-11-11 18:18:49 UTC - Size: 52.39 KB - 2 views
