Date/Time: Wed, 11 Nov 2026 15:39:31 +0000
Question
View Count: 5
[2026-11-11 15:21:48]
User437588 - Posts: 93
Hello
What is the best scaling setting for volatile markets?
I’ve tried all the options so far, and I’m generally satisfied with “Keep the Last Bar Within View” because SC runs smoothly with this setting. However, the adjustment to keep the price exactly in the center doesn’t quite work. What setting should I use?
I mainly use this for the 1-minute and 5-minute charts, which I run on other screens.
With all other settings, such as “Re-center the Last Bar,” Sierra Charts freezes on all other charts until the chart has adjusted. “Re-center the Last Bar on Every Update” makes me nervous when viewed from an angle.
Based on your experience, which setting would you use?
Thank you very much for your help.
image2026-11-11_16-13-02.jpg / V - Attached On 2026-11-11 15:21:32 UTC - Size: 156.18 KB - 1 views
