Date/Time: Mon, 09 Nov 2026 22:27:28 +0000
Can't move stop loss on ES, but can in ZN
View Count: 57
| [2026-11-09 16:21:32] |
| pinetrades - Posts: 17 |
Hi, I recently enabled the working order column in the DOM. Everything works great, except when I place a stop in the ES DOM, I cannot move it. I can move a stop in ZN just fine. I'm drawing ES data, but trading MES on the same DOM. I'm on version 2971. I can show a video of it if necessary. Thanks, |
| [2026-11-09 16:57:03] |
| John - SC Support - Posts: 48479 |
Is this with live trading or in Simulation Mode in Sierra Chart? We want to verify that you are using an ES chart and have the "Trade and Current Quote Symbol" set for MES, correct? And it is this chart that shows the issue? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-11-09 17:01:59] |
This is with live trading (I don't believe it works in SIM mode either). Yes, "Trade and Current Quote Symbol" is set to MES. This is on the DOM. I have attached a screenshot. The red 3 cannot be moved. I used to be able to move it. In ZN, I can move it. So it's just a problem with that specific DOM for some reason. |
| [2026-11-09 17:38:47] |
We can see that it has something to do with when you are only displaying the Quantity for a working order. For some reason, you can not move a working order line by the Quantity in a Trading DOM. But we are a bit confused by why you say you can do this with ZN, but not ES. Do you have anything else displayed with the ZN Trading DOM besides the quantity? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-11-09 17:41:13] |
I believe they are setup to be identical. I attached a screenshot showing an entry with a stop loss in ZN, which I am able to move.
