Date/Time: Mon, 09 Nov 2026 12:46:50 +0000
Feature Request: Numbers Bars Sign Filter
View Count: 8
| [2026-11-09 11:51:10] |
| Xeoh85 - Posts: 11 |
Hi Sierra Chart, I would like to create a numbers bars setup that has negative delta on the left and positive delta on the right. This can currently be approximated by having two Ask-Bid Volume Difference columns (the left right-aligned and the right left-aligned) and setting their positive (left) and negative (right) numbers to have the same color as the chart’s background (black), respectively. However, this does not look great if you have any other study that changes the chart’s background color or that occasionally underlays the numbers bars study, because the hidden (black) numbers and bars can then be seen. The simple solution to this would be to have the ability to filter a numbers bars column to show only positive or negative signed values, for both the column’s text and background fill method. Can we please get this feature? Thanks Date Time Of Last Edit: 2026-11-09 11:58:18
