Date/Time: Sun, 08 Nov 2026 12:38:32 +0000
Copy Chart Drawings from Chart #'s does not copy any drawings
View Count: 9
| [2026-11-08 12:11:57] |
| rayoone - Posts: 1 |
Version 2982, Windows. Setup, both charts in the SAME chartbook "Delta-foot-print_chart": - Source: Chart #1, ESZ26_FUT_CME, 1 Min - Destination: Chart #2, ESZ26_FUT_CME, 1 Min, created with Chart >> Duplicate Chart Same symbol, same bar period, same date-time range, both visible on screen. Destination chart #2, Chart >> Chart Settings >> Chart Drawings: - Copy Chart Drawings From Chart #'s = 1 - Hide/Disable User Drawn Chart Drawings From Other Charts = No - Show Chart Drawings for Different Symbols = No - Show Hidden Drawings = Yes - Draw Chart Drawings with Anchor Points Before First Date Time in Chart = Yes - Allow Modification of Chart Drawings from Other Charts = Yes Chart >> Hide Chart Drawings from Other Charts is unchecked on chart #2. Global Settings >> Tool Settings >> General >> Allow Copy To Other Charts For New Drawings = Yes. Verified with Tools >> Manage Chart Drawings Window: - Chart #1 lists 2 Rectangles, symbol ESZ26_FUT_CME, drawn directly on #1. They are not copies from another chart. - Chart #2 was emptied completely before the test. Its list is empty. - The rectangles span many bars, so the anchor mapping issue described in "Chart Drawings Not Visible in Destination Chart from Smaller Time Frame Per Bar Source Chart" does not apply. Result: no drawing appears on chart #2. Chart >> Reload and Recalculate on chart #2 changes nothing. I first had "#1" in the setting and then changed it to "1". No difference. I also tried copying across chartbooks, from "Delta-foot-print_chart:1" to a 2.50 Range chart in chartbook "range-foot-print_ES", with both chartbooks open. Same result, nothing is copied. I have gone through every item in "What to Do If Chart Drawings Do Not Copy" without success. 2026-11-08 06:50:49.219 | Trade activity files set size: 176 2026-11-08 06:50:49.352 | Reading Internal Order ID file. 2026-11-08 06:50:49.357 | Reading Trade Orders file. 2026-11-08 06:50:49.361 | Reading Trade Positions file. 2026-11-08 06:50:49.365 | Reading Trade Account Data files. 2026-11-08 06:50:49.371 | Software version: 2982 64-bit 2026-11-08 06:50:49.371 | Primary Thread ID: 49740 2026-11-08 06:50:49.371 | Usage end date: 2027-01-26 2026-11-08 06:50:49.371 | Enabled for: Advanced Features 2. 2026-11-08 06:50:49.371 | Enabled for: Sierra Chart Historical Data Service. 2026-11-08 06:50:49.371 | Enabled for: Denali Real-Time Exchange Data Feed. 2026-11-08 06:50:49.371 | Enabled for: Delayed Denali Exchange Data Feed. 2026-11-08 06:50:49.371 | Allow Support for Sierra Chart Data Feeds is enabled. 2026-11-08 06:50:49.371 | Current selected Data/Trading service: Teton CME Routing 2026-11-08 06:50:49.371 | Custom symbol settings values: enabled 2026-11-08 06:50:49.371 | Chart Update Interval: 400 2026-11-08 06:50:49.371 | Intraday Data Storage Time Unit: 0 2026-11-08 06:50:49.371 | Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) 2026-11-08 06:50:49.371 | 2026-11-08 11:50:49 Local computer time in UTC 2026-11-08 06:50:49.371 | 2026-11-08 06:50:49 Local computer time in SC Time Zone 2026-11-08 06:50:49.371 | 2026-11-08 11:50:44 Server time in UTC 2026-11-08 06:50:49.371 | Local computer UTC time and Server UTC time difference: 4 seconds. 2026-11-08 06:50:49.371 | Program path: C:\SierraChart\ 2026-11-08 06:50:49.371 | Data Files path: C:\SierraChart\Data\ 2026-11-08 06:50:49.371 | OS Version Number: 10.0 2026-11-08 06:50:49.371 | Locale Setting: C 2026-11-08 06:50:49.371 | Crash reporter started: true 2026-11-08 06:50:49.371 | 2026-11-08 06:50:49.386 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. 2026-11-08 06:50:49.387 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2026-11-08 06:50:49.518 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. Socket close state=2 2026-11-08 06:50:49.518 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2026-11-08 06:50:49.652 | Received 5 login tokens. 2026-11-08 06:50:49.871 | Symbol settings MD5 received. Request ID: 1. 2026-11-08 06:50:49.871 | Symbol settings are up-to-date for sc_futures_direct.dtc.trading. 2026-11-08 06:50:51.908 | Requested user files to download. 2026-11-08 06:50:52.500 | There are no user files to download. 2026-11-08 06:50:53.907 | 2026-11-08 06:50:53.907 | Teton CME Routing | Firm: Dorman/Stage5 2026-11-08 06:50:53.907 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11093 2026-11-08 06:50:53.944 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2026-11-08 06:50:53.944 | DTC Client socket (1) | New receive buffer size: 0 2026-11-08 06:50:53.944 | DTC Client socket (1) | Connecting to IP: 216.200.108.154 Port: 11093. 2026-11-08 06:50:54.060 | Teton CME Routing | Network connection to server complete. 2026-11-08 06:50:54.060 | Teton CME Routing | Starting socket receive thread. 2026-11-08 06:50:54.060 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2026-11-08 06:50:54.412 | Teton CME Routing | Setting DTC encoding to Binary VLS 2026-11-08 06:50:54.412 | Teton CME Routing | Sending logon request message. 2026-11-08 06:50:54.580 | Teton CME Routing | Received logon response. 2026-11-08 06:50:54.580 | Teton CME Routing | Server Name: SC DTC Server. Build=58073. 2026-11-08 06:50:54.580 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2026-11-08 06:50:54.580 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2026-11-08 06:50:54.580 | Teton CME Routing | Trading is supported. 2026-11-08 06:50:54.580 | Teton CME Routing | Order cancel and replace is supported. 2026-11-08 06:50:54.580 | Teton CME Routing | OCO Orders supported. 2026-11-08 06:50:54.580 | Teton CME Routing | Bracket Orders supported. 2026-11-08 06:50:54.580 | Teton CME Routing | MarketDepthIsSupported: 1 2026-11-08 06:50:54.580 | Teton CME Routing | Connection to server complete. 2026-11-08 06:50:54.581 | No download requests in the queue to start downloads for. | Number times message added: 4 2026-11-08 06:50:54.581 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2026-11-08 06:50:54.605 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 00:00:00.000000 2026-11-08 06:50:54.698 | Updated verified funded futures trading account ending date to: 2026-12-08 11:50:54 2026-11-08 06:50:57.131 | Files to Open on Startup | Opening file: ExampleChartbook.cht 2026-11-08 06:50:57.380 | MNQM26_FUT_CME 1 Min #6 | Reloading chart. 2026-11-08 06:50:57.397 | MNQM26_FUT_CME 5 Min #1 | Reloading chart. 2026-11-08 06:50:57.500 | MNQM26_FUT_CME 15 Min #2 | Reloading chart. 2026-11-08 06:50:57.625 | MNQM26_FUT_CME 60 Min #3 | Reloading chart. 2026-11-08 06:50:57.822 | MNQM26_FUT_CME 240 Min #4 | Reloading chart. 2026-11-08 06:50:57.987 | MNQM26_FUT_CME [CBV] Daily #5 | Reloading chart. 2026-11-08 06:50:58.097 | MNQM26_FUT_CME [CBV] Daily #5 | Performing continuous chart historical Daily data download for symbol MNQM26_FUT_CME starting at last date in file. 2026-11-08 06:50:58.097 | Starting DelayedDownloadMonitoringTimer 2026-11-08 06:50:58.097 | Starting HDTimeoutTimer 2026-11-08 06:50:58.097 | Added historical Daily data request for MNQM26_FUT_CME to the queue. 2026-11-08 06:50:58.098 | Triggering next historical data download in queue. 2026-11-08 06:50:58.251 | MNQM26_FUT_CME [CBV] Daily #5 | Waiting for historical downloads to complete with the IDs: 1, 2026-11-08 06:50:58.279 | Removing historical data download ID 1. 2026-11-08 06:50:58.279 | Mapping MNQM26_FUT_CME to MNQM26. Service code: cme 2026-11-08 06:50:58.279 | Using symbol data fast lookup vector 2026-11-08 06:50:58.281 | HD Request # 1 | Downloading Historical Daily chart data for MNQM26_FUT_CME. Starting date: 2026-06-16. Service: sc_futures_direct.dtc.trading 2026-11-08 06:50:58.292 | Delayed Data Feed | Starting real-time market data updates for: MNQM26_FUT_CME (MNQM26). ID: 1 Service code: cme 2026-11-08 06:50:58.292 | Delayed Data Feed | Connecting to the server ds25.sierracharts.com. Port 10043 2026-11-08 06:50:58.292 | Delayed Data Feed | Requesting security definition data for: MNQM26_FUT_CME (MNQM26). ID: 1 2026-11-08 06:50:58.292 | Starting DelayedDownloadMonitoringTimer 2026-11-08 06:50:58.292 | Starting HDTimeoutTimer 2026-11-08 06:50:58.292 | Added historical Intraday data request for MNQM26_FUT_CME to the queue. 2026-11-08 06:50:58.292 | Intraday data recording state for symbol MNQM26_FUT_CME is set to download 'Pending'. 2026-11-08 06:50:58.293 | Triggering next historical data download in queue. 2026-11-08 06:50:58.293 | Removing historical data download ID 2. 2026-11-08 06:50:58.293 | Delaying start of download for MNQM26_FUT_CME. 2026-11-08 06:50:58.325 | DTC Client socket (3) | Creating socket. 2026-11-08 06:50:58.325 | DTC Client socket (3) | New receive buffer size: 0 2026-11-08 06:50:58.325 | DTC Client socket (3) | Connecting to IP: 64.152.155.20 Port: 10043. 2026-11-08 06:50:58.446 | Delayed Data Feed | Network connection to server complete. 2026-11-08 06:50:58.446 | Delayed Data Feed | Starting socket receive thread. 2026-11-08 06:50:58.447 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-11-08 06:50:58.578 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2026-11-08 06:50:58.578 | Delayed Data Feed | Sending logon request message. 2026-11-08 06:50:58.883 | HD Request # 1 | Requesting historical Daily data for NMM26 starting at 2026-06-15. SC External HD service. 2026-11-08 06:50:59.140 | Delayed Data Feed | Received logon response. 2026-11-08 06:50:59.140 | Delayed Data Feed | Server Name: SC Realtime Server. 2026-11-08 06:50:59.140 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2026-11-08 06:50:59.140 | Delayed Data Feed | Successfully connected. 2026-11-08 06:50:59.140 | Delayed Data Feed | Trading is not supported. 2026-11-08 06:50:59.140 | Delayed Data Feed | MarketDepthIsSupported: 1 2026-11-08 06:50:59.140 | Delayed Data Feed | Restarting real-time data updates for symbol: MNQM26_FUT_CME -> MNQM26 2026-11-08 06:50:59.207 | HD Request # 1 | Receiving historical Daily data for MNQM26_FUT_CME starting at 2026-06-16. 2026-11-08 06:50:59.207 | HD Request # 1 | Writing historical Daily data to the file MNQM26_FUT_CME.dly. 2026-11-08 06:50:59.209 | HD Request # 1 | Bytes received: 245 2026-11-08 06:50:59.209 | HD Request # 1 | Received 4 Daily data records from 2026-06-16 00:00:00 to 2026-06-18 00:00:00 (3.0 days) and wrote 3 records for MNQM26_FUT_CME 2026-11-08 06:50:59.209 | HD Request # 1 | Completion time: 1s. 2026-11-08 06:50:59.209 | HD Request # 1 | Daily data download complete for MNQM26_FUT_CME. Unique request ID: 1 2026-11-08 06:50:59.209 | Removing historical data download ID 1. 2026-11-08 06:50:59.209 | 2026-11-08 06:50:59.209 | No download requests in the queue to start downloads for. 2026-11-08 06:50:59.209 | MNQM26_FUT_CME [CBV] Daily #5 | Download is complete for all contract months in chart. Proceeding with data load. 2026-11-08 06:50:59.217 | MNQM26_FUT_CME [CBV] Daily #5 | Reloading chart. 2026-11-08 06:50:59.335 | MNQM26_FUT_CME [CBV] Daily #5 | Chart data loading complete. 2026-11-08 06:50:59.359 | Starting DelayedDownloadMonitoringTimer 2026-11-08 06:50:59.359 | Starting HDTimeoutTimer 2026-11-08 06:50:59.359 | Added historical Market Depth data request for MNQM26_FUT_CME to the queue. 2026-11-08 06:50:59.359 | Market depth data recording state for symbol MNQM26_FUT_CME is set to download 'Pending'. 2026-11-08 06:50:59.359 | Triggering next historical data download in queue. 2026-11-08 06:50:59.359 | Historical Market Depth data request, start 00:00:00.000 , for MNQM26_FUT_CME is discarded because a matching download is already pending and the new one is not for earlier data. 2026-11-08 06:50:59.359 | Delayed Data Feed | Real-time data for symbol MNQM26_FUT_CME is currently unavailable. 2026-11-08 06:50:59.359 | Delayed Data Feed | Received security definition for symbol MNQM26_FUT_CME 2026-11-08 06:50:59.359 | Removing historical data download ID 3. 2026-11-08 06:50:59.359 | HD Request # 2 | Downloading Market Depth data for MNQM26_FUT_CME. Service: cme.marketdepth. 2026-11-08 06:50:59.379 | HD Request # 2 | Download start date-time: 2026-11-07 11:05:48.642509. 2026-11-08 06:50:59.379 | HD Request # 2 | Using server: ds37.sierracharts.com port 10149 2026-11-08 06:50:59.401 | Socket (5) | Creating socket. 2026-11-08 06:50:59.401 | Socket (5) | New receive buffer size: 0 2026-11-08 06:50:59.401 | Socket (5) | Connecting to IP: 4.8.175.92 Port: 10149. 2026-11-08 06:50:59.592 | Requesting market depth updates for: MNQM26_FUT_CME if supported. NumLevels=1400 2026-11-08 06:50:59.624 | MNQM26_FUT_CME [CBV] Daily #5 | Reloading chart. 2026-11-08 06:50:59.663 | HD Request # 2 | Setting DTC encoding to Binary VLS 2026-11-08 06:50:59.663 | HD Request # 2 | Sending historical data logon request message. 2026-11-08 06:50:59.851 | HD Request # 2 | Requesting market depth data. Start date-time: 2026-11-07 11:05:48. Symbol: MNQM26 2026-11-08 06:50:59.872 | Delayed Data Feed | Clearing market depth for MNQM26_FUT_CME 2026-11-08 06:50:59.896 | MNQM26_FUT_CME [CBV] Daily #5 | Chart data loading complete. 2026-11-08 06:50:59.982 | Socket (5) | CloseSocket call. 2026-11-08 06:50:59.982 | HD Request # 2 | Error downloading historical Market Depth data for MNQM26_FUT_CME. No market depth data files found for request. Path: E:\cme_exchange_marketdepth.data\ 2026-11-08 06:50:59.982 | Socket (5) | Shutdown started. Waiting for graceful close. 2026-11-08 06:50:59.983 | Historical data download thread signaled to stop. 2026-11-08 06:50:59.983 | HD Request # 2 | Received 0 Market Depth data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for MNQM26_FUT_CME 2026-11-08 06:50:59.983 | HD Request # 2 | Completion time: 0s. 2026-11-08 06:50:59.983 | HD Request # 2 | Market Depth data download complete for MNQM26_FUT_CME. Unique request ID: 3 2026-11-08 06:50:59.983 | Real-time market depth file updates started for MNQM26_FUT_CME 2026-11-08 06:50:59.983 | Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\MNQM26_FUT_CME.2026-11-08.depth 2026-11-08 06:50:59.983 | Removing historical data download ID 3. 2026-11-08 06:50:59.983 | 2026-11-08 06:50:59.983 | No download requests in the queue to start downloads for. 2026-11-08 06:51:00.111 | Socket (5) | Socket gracefully closed by remote side. Socket close state=2 2026-11-08 06:51:00.111 | Socket (5) | Closed. 2026-11-08 06:51:04.313 | HD Request # 3 | Downloading Intraday chart data for MNQM26_FUT_CME to the file MNQM26_FUT_CME.scid. Service: cme 2026-11-08 06:51:04.357 | HD Request # 3 | Download start date-time: 2026-06-18 09:29:59.000000. File last date-time: 2026-06-18 09:29:59.974000 2026-11-08 06:51:04.357 | HD Request # 3 | Using server: ds32.sierracharts.com port 10149 2026-11-08 06:51:04.378 | Socket (2) | Creating socket. 2026-11-08 06:51:04.379 | Socket (2) | New receive buffer size: 0 2026-11-08 06:51:04.379 | Socket (2) | Connecting to IP: 69.39.70.248 Port: 10149. 2026-11-08 06:51:04.627 | HD Request # 3 | Setting DTC encoding to Binary VLS 2026-11-08 06:51:04.627 | HD Request # 3 | Sending historical data logon request message. 2026-11-08 06:51:04.783 | HD Request # 3 | Requesting Intraday data. Start date-time: 2026-06-18 09:29:59. Record interval: 0. Symbol: MNQM26 2026-11-08 06:51:04.909 | HD Request # 3 | Decompressing data. 2026-11-08 06:51:05.084 | HD Request # 3 | Receiving Intraday data for MNQM26_FUT_CME starting at 2026-06-18 09:29:59.319000 2026-11-08 06:51:05.084 | Socket (2) | CloseSocket call. 2026-11-08 06:51:05.084 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-11-08 06:51:05.085 | Historical data download thread signaled to stop. 2026-11-08 06:51:05.085 | HD Request # 3 | Received 2 Intraday data records from 2026-06-18 09:29:59.319000 to 2026-06-18 09:29:59.974000 (0.7 seconds. Delay: 142.9 days) and wrote 0 records for MNQM26_FUT_CME 2026-11-08 06:51:05.196 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2026-06-18 13:29:59.974000 2026-11-08 06:51:05.196 | HD Request # 3 | Completion time: 1s. 2026-11-08 06:51:05.196 | HD Request # 3 | Intraday data download complete for MNQM26_FUT_CME. Unique request ID: 2 2026-11-08 06:51:05.196 | Real-time Intraday chart data file updates started for MNQM26_FUT_CME 2026-11-08 06:51:05.196 | Intraday chart data file opened for MNQM26_FUT_CME 2026-11-08 06:51:05.196 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2026-11-08 06:51:05.196 | Removing historical data download ID 2. 2026-11-08 06:51:05.196 | 2026-11-08 06:51:05.196 | No download requests in the queue to start downloads for. 2026-11-08 06:51:05.208 | Socket (2) | Socket gracefully closed by remote side. Socket close state=2 2026-11-08 06:51:05.208 | Socket (2) | Closed. 2026-11-08 06:51:14.704 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2026-11-08 06:51:15.292 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2026-12-05"}. Success=true 2026-11-08 06:51:20.351 | MNQM26_FUT_CME[M] 1 Min #6 | Chart data loading complete. 2026-11-08 06:51:28.910 | MNQM26_FUT_CME[M] 15 Min #2 | Chart data loading complete. 2026-11-08 06:51:28.910 | MNQM26_FUT_CME[M] 60 Min #3 | Chart data loading complete. 2026-11-08 06:51:28.930 | MNQM26_FUT_CME[M] 5 Min #1 | Chart data loading complete. 2026-11-08 06:51:28.930 | MNQM26_FUT_CME[M] 240 Min #4 | Chart data loading complete. 2026-11-08 06:51:37.519 | ESZ26_FUT_CME 1 Min #1 | Reloading chart. 2026-11-08 06:51:37.566 | ESZ26_FUT_CME 2.50 Range #3 | Reloading chart. 2026-11-08 06:51:37.734 | ESZ26_FUT_CME [CV] 1 Min #2 | Reloading chart. 2026-11-08 06:51:39.665 | ESZ26_FUT_CME [CV] 1 Min #2 | Performing continuous chart historical Daily data download for symbol ESZ26_FUT_CME starting at last date in file. 2026-11-08 06:51:39.665 | Added historical Daily data request for ESZ26_FUT_CME to the queue. 2026-11-08 06:51:39.665 | Triggering next historical data download in queue. 2026-11-08 06:51:39.814 | ESZ26_FUT_CME [CV] 1 Min #2 | Waiting for historical downloads to complete with the IDs: 5, 2026-11-08 06:51:39.830 | Removing historical data download ID 5. 2026-11-08 06:51:39.831 | Mapping ESZ26_FUT_CME to ESZ26. Service code: cme 2026-11-08 06:51:39.832 | HD Request # 4 | Downloading Historical Daily chart data for ESZ26_FUT_CME. Starting date: 2026-11-04. Service: sc_futures_direct.dtc.trading 2026-11-08 06:51:39.853 | Delayed Data Feed | Starting real-time market data updates for: ESZ26_FUT_CME (ESZ26). ID: 2 Service code: cme 2026-11-08 06:51:39.853 | Delayed Data Feed | Requesting security definition data for: ESZ26_FUT_CME (ESZ26). ID: 2 2026-11-08 06:51:39.853 | Added historical Intraday data request for ESZ26_FUT_CME to the queue. 2026-11-08 06:51:39.853 | Intraday data recording state for symbol ESZ26_FUT_CME is set to download 'Pending'. 2026-11-08 06:51:39.853 | Triggering next historical data download in queue. 2026-11-08 06:51:39.854 | Removing historical data download ID 6. 2026-11-08 06:51:39.854 | Delaying start of download for ESZ26_FUT_CME. 2026-11-08 06:51:40.055 | Delayed Data Feed | Setting external service identifier for symbol ESZ26_FUT_CME to 10252 2026-11-08 06:51:40.055 | Delayed Data Feed | Received security definition for symbol ESZ26_FUT_CME 2026-11-08 06:51:40.427 | HD Request # 4 | Requesting historical Daily data for ESZ26 starting at 2026-11-03. SC External HD service. 2026-11-08 06:51:40.707 | HD Request # 4 | Receiving historical Daily data for ESZ26_FUT_CME starting at 2026-11-04. 2026-11-08 06:51:40.708 | HD Request # 4 | Writing historical Daily data to the file ESZ26_FUT_CME.dly. 2026-11-08 06:51:40.716 | HD Request # 4 | Bytes received: 229 2026-11-08 06:51:40.716 | HD Request # 4 | Received 4 Daily data records from 2026-11-04 00:00:00 to 2026-11-06 00:00:00 (3.0 days) and wrote 3 records for ESZ26_FUT_CME 2026-11-08 06:51:40.716 | HD Request # 4 | Completion time: 1s. 2026-11-08 06:51:40.716 | HD Request # 4 | Daily data download complete for ESZ26_FUT_CME. Unique request ID: 5 2026-11-08 06:51:40.716 | Removing historical data download ID 5. 2026-11-08 06:51:40.716 | 2026-11-08 06:51:40.716 | No download requests in the queue to start downloads for. 2026-11-08 06:51:40.977 | ESZ26_FUT_CME [CV] 1 Min #2 | Download is complete for all contract months in chart. Proceeding with data load. 2026-11-08 06:51:41.106 | ESZ26_FUT_CME [CV] 1 Min #2 | Reloading chart. | Number times message added: 1 2026-11-08 06:51:45.367 | HD Request # 5 | Downloading Intraday chart data for ESZ26_FUT_CME to the file ESZ26_FUT_CME.scid. Service: cme 2026-11-08 06:51:45.709 | HD Request # 5 | Download start date-time: 2026-11-06 16:59:59.000000. File last date-time: 2026-11-06 16:59:59.872000 2026-11-08 06:51:45.709 | HD Request # 5 | Using server: ds28.sierracharts.com port 10150 2026-11-08 06:51:45.732 | Socket (2) | Creating socket. 2026-11-08 06:51:45.732 | Socket (2) | New receive buffer size: 0 2026-11-08 06:51:45.732 | Socket (2) | Connecting to IP: 67.214.125.5 Port: 10150. 2026-11-08 06:51:45.976 | HD Request # 5 | Setting DTC encoding to Binary VLS 2026-11-08 06:51:45.976 | HD Request # 5 | Sending historical data logon request message. 2026-11-08 06:51:46.126 | HD Request # 5 | Requesting Intraday data. Start date-time: 2026-11-06 16:59:59. Record interval: 0. Symbol: ESZ26 2026-11-08 06:51:46.238 | HD Request # 5 | Decompressing data. 2026-11-08 06:51:46.356 | HD Request # 5 | Receiving Intraday data for ESZ26_FUT_CME starting at 2026-11-06 16:59:59.035000 2026-11-08 06:51:46.356 | Socket (2) | CloseSocket call. 2026-11-08 06:51:46.356 | Socket (2) | Shutdown started. Waiting for graceful close. 2026-11-08 06:51:46.356 | Historical data download thread signaled to stop. 2026-11-08 06:51:46.356 | HD Request # 5 | Received 53 Intraday data records from 2026-11-06 16:59:59.035000 to 2026-11-06 16:59:59.872000 (0.8 seconds. Delay: 37.9 hours) and wrote 0 records for ESZ26_FUT_CME 2026-11-08 06:51:46.456 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2026-11-06 21:59:59.872000 2026-11-08 06:51:46.456 | HD Request # 5 | Completion time: 1s. 2026-11-08 06:51:46.456 | HD Request # 5 | Intraday data download complete for ESZ26_FUT_CME. Unique request ID: 6 2026-11-08 06:51:46.456 | Real-time Intraday chart data file updates started for ESZ26_FUT_CME 2026-11-08 06:51:46.456 | Intraday chart data file opened for ESZ26_FUT_CME 2026-11-08 06:51:46.456 | HD Request # 5 | Enabling Intraday chart updating for symbol. 2026-11-08 06:51:46.456 | Removing historical data download ID 6. 2026-11-08 06:51:46.456 | 2026-11-08 06:51:46.456 | No download requests in the queue to start downloads for. 2026-11-08 06:51:46.475 | Socket (2) | Socket gracefully closed by remote side. Socket close state=2 2026-11-08 06:51:46.475 | Socket (2) | Closed. 2026-11-08 06:51:48.885 | ESZ26_FUT_CME[M] 1 Min #1 | Chart data loading complete. 2026-11-08 06:51:48.985 | ESZ26_FUT_CME[M] 2.50 Range #3 | Chart data loading complete. 2026-11-08 06:54:50.180 | + Loading additional symbol data. 2026-11-08 06:54:50.886 | Mapping VXM26-CFE to VXM26_FUT_CFE. Service code: cfe_exchange.data 2026-11-08 06:54:50.886 | Delayed Data Feed | Starting real-time market data updates for: VXM26-CFE (VXM26_FUT_CFE). ID: 3 Service code: cfe_exchange.data 2026-11-08 06:54:50.886 | Delayed Data Feed | Connecting to the server ds33.sierracharts.com. Port 10043 2026-11-08 06:54:50.887 | Delayed Data Feed | Requesting security definition data for: VXM26-CFE (VXM26_FUT_CFE). ID: 3 2026-11-08 06:54:50.887 | Added historical Intraday data request for VXM26-CFE to the queue. 2026-11-08 06:54:50.887 | Intraday data recording state for symbol VXM26-CFE is set to download 'Pending'. 2026-11-08 06:54:50.887 | Triggering next historical data download in queue. 2026-11-08 06:54:50.887 | ESZ26_FUT_CME [CV][M] 1 Min #2 | Started historical data download for additional symbol VXM26-CFE. Download ID: 7 2026-11-08 06:54:50.925 | DTC Client socket (2) | Creating socket. 2026-11-08 06:54:50.925 | DTC Client socket (2) | New receive buffer size: 0 2026-11-08 06:54:50.925 | DTC Client socket (2) | Connecting to IP: 69.39.70.245 Port: 10043. 2026-11-08 06:54:51.256 | ESZ26_FUT_CME [CV][M] 1 Min #2 | Chart data loading complete. 2026-11-08 06:54:51.257 | Removing historical data download ID 7. 2026-11-08 06:54:51.257 | Delaying start of download for VXM26-CFE. 2026-11-08 06:54:51.257 | Delayed Data Feed | Network connection to server complete. 2026-11-08 06:54:51.257 | Delayed Data Feed | Starting socket receive thread. 2026-11-08 06:54:51.257 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2026-11-08 06:54:51.386 | Delayed Data Feed | Setting DTC encoding to Binary VLS 2026-11-08 06:54:51.386 | Delayed Data Feed | Sending logon request message. 2026-11-08 06:54:51.604 | Delayed Data Feed | Received logon response. 2026-11-08 06:54:51.604 | Delayed Data Feed | Server Name: SC Realtime Server. 2026-11-08 06:54:51.604 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8 2026-11-08 06:54:51.604 | Delayed Data Feed | Successfully connected. 2026-11-08 06:54:51.604 | Delayed Data Feed | Trading is not supported. 2026-11-08 06:54:51.604 | Delayed Data Feed | MarketDepthIsSupported: 1 2026-11-08 06:54:51.604 | Delayed Data Feed | Restarting real-time data updates for symbol: VXM26-CFE -> VXM26_FUT_CFE 2026-11-08 06:54:51.823 | Delayed Data Feed | Real-time data for symbol VXM26-CFE is currently unavailable. 2026-11-08 06:54:51.823 | Delayed Data Feed | Received security definition for symbol VXM26-CFE 2026-11-08 06:54:56.308 | HD Request # 6 | Downloading Intraday chart data for VXM26-CFE to the file VXM26-CFE.scid. Service: cfe_exchange.data 2026-11-08 06:54:56.308 | HD Request # 6 | Download start date-time: 2026-06-17 08:58:59.000000. File last date-time: 2026-06-17 08:58:59.937000 2026-11-08 06:54:56.308 | HD Request # 6 | Using server: ds30.sierracharts.com port 10149 2026-11-08 06:54:56.328 | Socket (4) | Creating socket. 2026-11-08 06:54:56.328 | Socket (4) | New receive buffer size: 0 2026-11-08 06:54:56.328 | Socket (4) | Connecting to IP: 67.214.125.11 Port: 10149. 2026-11-08 06:54:56.585 | HD Request # 6 | Setting DTC encoding to Binary VLS 2026-11-08 06:54:56.585 | HD Request # 6 | Sending historical data logon request message. 2026-11-08 06:54:56.742 | HD Request # 6 | Requesting Intraday data. Start date-time: 2026-06-17 08:58:59. Record interval: 0. Symbol: VXM26_FUT_CFE 2026-11-08 06:54:56.865 | HD Request # 6 | Decompressing data. 2026-11-08 06:54:56.986 | HD Request # 6 | Receiving Intraday data for VXM26-CFE starting at 2026-06-17 08:58:59.051000 2026-11-08 06:54:56.986 | Socket (4) | CloseSocket call. 2026-11-08 06:54:56.986 | Socket (4) | Shutdown started. Waiting for graceful close. 2026-11-08 06:54:56.986 | Historical data download thread signaled to stop. 2026-11-08 06:54:56.986 | HD Request # 6 | Received 3 Intraday data records from 2026-06-17 08:58:59.051000 to 2026-06-17 08:58:59.937000 (0.9 seconds. Delay: 144.0 days) and wrote 0 records for VXM26-CFE 2026-11-08 06:54:56.987 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2026-06-17 12:58:59.937000 2026-11-08 06:54:56.987 | HD Request # 6 | Completion time: 0s. 2026-11-08 06:54:56.987 | HD Request # 6 | Intraday data download complete for VXM26-CFE. Unique request ID: 7 2026-11-08 06:54:56.987 | Real-time Intraday chart data file updates started for VXM26-CFE 2026-11-08 06:54:56.987 | Intraday chart data file opened for VXM26-CFE 2026-11-08 06:54:56.987 | HD Request # 6 | Enabling Intraday chart updating for symbol. 2026-11-08 06:54:56.987 | ESZ26_FUT_CME [CV][M] 1 Min #2 | Historical data download for additional symbol VXM26-CFE with ID 7 has completed. 2026-11-08 06:54:56.987 | Removing historical data download ID 7. 2026-11-08 06:54:56.987 | 2026-11-08 06:54:56.987 | No download requests in the queue to start downloads for. 2026-11-08 06:54:57.114 | Socket (4) | Socket gracefully closed by remote side. Socket close state=2 2026-11-08 06:54:57.114 | Socket (4) | Closed. 2026-11-08 06:58:07.039 | Saved Chartbook: ExampleChartbook.cht. Time: 0.0061 seconds. 2026-11-08 06:58:07.046 | Saved Chartbook: Delta-foot-print_chart.Cht. Time: 0.0068 seconds. Date Time Of Last Edit: 2026-11-08 12:19:45
Private File Private File |
