Date/Time: Sat, 07 Nov 2026 11:32:48 +0000
User defined variables - Spreadsheet system for trading
View Count: 4
| [2026-11-07 11:12:25] |
| Judge Kilday - Posts: 31 |
Hi I used to use cells J121 - J128 as user defined variables for my Spreadsheet system for trading formulas. Now when I reference these cells in a formula as an absolute reference (eg. $J$124) it no longer picks up the variable and adjusts my formula output. (My formulas work if I manually change the cell reference such as $J$124 to the number I want like say 0.8 so I know my formulas work otherwise). I have updated my sierra chart version. I’m using version 2922 revision 57220. Has there been a change to how/where the user defined variables are used? I can’t find this in the help pages. can you assist? Thanks |
